CSI Safe - Rebar Objects
EngTipper.
CA
For some reason the "Slab rebar objects" line is not available under the model explorer in SAFE 20.3 (attached). I'm therefore not able to look at all of the different rebar objects in the model.
Is there is a setting that can add this item back to the list?
 https://files.engineering.com/getfile.aspx?folder=bba09566-0b2d-4e10-a0c1-1cec7ee823fe&file=Capture.PNG
Contact CSI support. They're pretty good and respond quickly for most things. Sorry I can't answer your question. It might just be a case of an important feature getting taken out.
/start rant/
Honestly, I hate when they change versions. They fix some things but mess up other things. For ETABS, since 2018, the steel design deflections has not been working correctly for AISC code, and I use ETABS 2016 for that reason. And I'm paying thousands a year for it! They've been working on that little problem since 2018, and it's still in development. It pisses me off. And they took away the rendered view! WHY, CSI? WHY DO YOU DO THIS TO ME?
/end rant/
