cts & pts
wirepuller
CA
Iam installing cts & pts in a small area for three controlers.one controler has 3 cts & 6 pts. The other two controlers,will share 3 cts & 3 pts. The voltage is 4160 3 phase delta. What is the spaceing needed between cts and pts. 3 cts & 3pts are on the line side of a generator.3 pts on line side of incomming main supply. There is two contactors one for generator, & one for incomming main power with load sides of contactors tied together, where the other 3 cts & pts will be mounted. Can you help me out or where i can get information from. thanks
