Cumulate dimensions with VBA (.catvba)
Thomas D
FR
I want to make dimensions between a first point "Origine" and a second point ("Point.1") on horizontal axis and vertical axis, I made this and it works:
Code:
Sub CATMain()
 Set DrwDocument = CATIA.ActiveDocument 'drawingDocument1
 Set DrwSheets = DrwDocument.Sheets 'drawingSheets1
 Set DrwSheet = DrwSheets.ActiveSheet 'drawingSheet1
 Set DrwViews = DrwSheet.Views 'drawingViews1
 Set DrwView = DrwSheet.Views.ActiveView
 Set Fact2D = DrwView.Factory2D
 Set GeoElments = DrwView.GeometricElements
 Dim DrwDimensions As DrawingDimensions
 Set DrwDimensions = DrwViews.Item("Vue de face")
 Dim myElements
 Dim selpoints
 Dim MyDimension As DrawingDimension
 Set origine = GeoElments.Item("Origine")
 Set Point = GeoElments.Item("Point.1")
 myElements = Array(origine, Point)
 selpoints = Array(0, 0, 0, 0)
 Set MyDimension = DrwView.Dimensions.Add(catDimDistance, myElements, selpoints, catDimHoriz)
 Set MyDimension = DrwView.Dimensions.Add(catDimDistance, myElements, selpoints, catDimVert)
End Sub
there is the result:
But, I want cumulate dimensions like this:
I found CatDimMode with catDimCumulate for cumulate dimension in Catia doc, but I don't know how to apply it to "MyDimension".
Thanks in advance for your help
PS: Sorry for the possible English error I'm French
