Hello guys,
I have a question regarding cupola structure that I work on right now. It's a wood structure with two steel beams (compression and tension ring beams). Please see attached two diagrams, axial force and bending moments. The model is simplified for calculations' sake. Horizontal rafters as modeled as pin connected with two steel beams. Is it possible to completely eliminate bending moment in the tension collar beam, or will it always act as a beam considering the fact that load is applied to the surface etc..? Thanks
