I am trying to customize the menu when you go File > New.
When the menu opens and you select model and select one of the items, down below it has two boxes:
Name:
Folder:
How do I go about adding a box for Description and then assigning it to an attribute?
A previous job had this, and it was super helpful because when making a part if you knew the part description, you didn't have to go into the attributes and fill it out later.
Name:
Folder:
