Cut voxel element
NEROOO
36
I have got two models with the same dimension, are both meshed with the C3D8 voxels, without any geometry instance in the model.
What I'm trying to do is to delete the overlapping voxels between two models, like the function as "cut instance".
Looking for some help!
Thanks!
So basically you have orphan mesh part. In such case you can operate on individual elements using Edit Mesh tools (this also includes dividing and merging elements) but you may also use merge meshes with Merge/Cut Instances tool.
