vanpeltnv
Industrial
- Feb 10, 2004
- 27
To make holes in a part we work like this :
We have parts that we use as cut outs, we make a subassembly with one part and a part that whe use as cut out
(for each part we have also a cut out).
Then we make an assembly where whe assemble a main part and the subassemblies, then we make cut outs in the
main part. If whe change the possition of a subassembly the possition of the cut out changes also.
Problem with these cut outs is you cannot make a holetable, you can not do a show/errase dimensions in a drawing.
Question : Is it not possible to make a subassembly with a part and with a hole feature so when you assemble
this in a main assembly the hole gets in the main part.
