Cycle times
Acroloc
Industrial
May 26, 2009
4
After post processing a program in NX 6.0
is there a way for the software to give me an aprox.
cycle time?
You can see the machine time on the Operation Navigiator
Attached is a custom command that you can add to the end of path event. This will output the run time for each operation and the total time. I did not write this code it was given to me.
Good luck
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
NX3,4,5,6 Solid Works, Pro/e, Solid Edge
