Cylindrical shell thickess
AMinati
IT
I'm checking some calculations of my software for the minimum thickness of a cylindrical shell. I do not understand why I get different results if I use the formula UG-27 (1) from the one that uses the Mandatory Appendix 1 (1).
The condition "P does not exceed 0.385SE" is satisfied but I get the same results only if in the formula UG-27 (1) I consider R as the outer radius of the cylindrical shell and not the internal one as defined in UG-27(b) and specified in note 19: “For pipe, the inside radius R is determined by the nominal outside radius minus the nominal wall thickness.”
Where am I doing wrong?
Any help will be appreciate
Best Regards
AMinati
AMinati, OD formula and ID formula will give slightly different results. Either is acceptable.
Mike
