My company hired me about a month ago as the QC Manager. I was an AI for 2 years, and in the navy for 9. I have lots of QC experience. I was hired on to help change things for them, and to promote growth by getting the company certified in the AISC SBR program. I have made the manual, and procedures required, but now I am putting together the WPS and PQR's for submittal with the application. My company has never welded on bridges. They have ASME stamps and all their weld procedures are based on Section IX, although most are wrong or outdated at best. As I have read through the D1.5 I noticed that the requirements are way more restrictive, and thus make things a litte tougher for qualification. We just bought a sub arc machine, at my request, and this will be the first test of that machine. I see in the D1.5 that it calls out for the use of of steel of having a tensile strenght of 50ksi or more, which isn't a problem. We use A36 on almost all work we perform, my issue regards using that material for test purposes. I don't have the ASTM Spec form AWS, and won't until January as my budget has run out, but I would like to set up my procedures for the test. Is A36 plate comparable to the required specs for D1.5, and if so, if using a 1" plate for testing, would backing be required or could back gouging be used in its stead? I know I posted a lot of info for such a short question, but like I said I am new to D1.5 so I want to make sure I get it right the first time.
