I work in an OSB mill where 44 D2 knifes approx. 1/4" x 4" x 21", treated to 58-60, are used to flake or strand logs. The knives are held in a knife pack that has an outer retaining bar made of mild steel. Occasionally these knife packs load and friction creates heat to I assume, 500 plus degrees F as the edge of the mild steel bars that retain the D2 knifes, turns blue. Then, as part of the process, the cutting ring returns to home where the knife packs are sprayed with water and the cutting process repeats. My question is, what effects if any, does the combination of heating to that temperature and spraying with water have on the knife edges. Occasionally when we change the knife packs the edges are damaged, some appear to be softened and peened over and others seem to be brittle and fractured. Could the heat and water be the culprit.
Thanks-
Thanks-
