Ezra Shemuly
- Dec 9, 2024
- 2
Hello all
(apologies for the low resolution picture, the matter is out of my hands)
the question at hand is a section of a slip-joint monopole that was damaged during off-loading at the client's warehouse
the monopole was designed based on TIA-222-H and should comply to all relevant American standards and regulations
is there a limitation or rule that limits the client from trying to fix this damage and using the damaged section?
meaning - can I quote a specific paragraph in a standard (that I'm not aware of) that prohibits the use of such a part after it was repaired?
also - what is the relevant standard that outlines the acceptable tolerances for such a repair? assuming I cannot prohibit the usage of the repaired part?
thank you
thank you
