Canada580
- Aug 26, 2014
- 17
I am trying to measure structural damping value (For the First mode of vibration) of a steel pole (pipe Section) with Logarithmic decrement method. When I excited the pole, the excitation axis is changing. It is mainly because the circular section have same stiffness about all axis passing through center. Saying that, I got significant acceleration values in both X and Y axis. Now the question is: how do I combine the X and Y values of acceleration to get resultant acieration time history diagram accounting both positive and negative values so that I can use logarithmic decrement method to calculate damping?
As a way, probably I can calculate resultant acceleration and provide positive or negative sign to it base on predominant axis of vibration as in the attached file ? But little doubt as the axis of vibration is changing with time.
Any methodology for such resultant acceleration time history and find damping from that or any literature ? any reference ?
Much appreciate for any help.
Thank you.
Thank you.
