Data Report 1
gayaz
18
I have different data report's like Manufacturer's data report, partial data report etc in keyform software. I have lot of problems maintaing the data or reproducing it. my question is is there a way u can get the data report in electronic form such as in microsoftword or Acess where i can maintain good data base. or can i develop these forms, does ASME allows us to do so. help is appreciated
thank you
I keep welding forms in access databases. These are recommended formats by ASME.
I'm not sure about the other forms.
Another option is using access or another database application to fill out pre-printed forms. The data fields can be precisely located on a report in access and blank forms inserted into your printer.
The format of the ASME form can probably be reproduced easily unless unusual fonts are used.
