Anybody found a workaround for the date format limitations in Inventor?
Current advice from Autodesk is to change the system format definition.
Not a practical solution - that would affect MANY other programs running on this computer, some adversely.
For clarity, I'm asking about Inventor's ability to use a date format such as: DD-MMM-YY instead of, say, MM/DD/YY as set by the operating system.
AFAIK, there is no setting in Inventor that allows you to select the format you want - preventing you from standardizing the configuration of Inventor among the workgroup without standardizing the date format of Windows on every computer, too, regardless of its other uses or the user's needs.
STF
STF
