  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Datum elements color change
Vertx
Automotive
Jan 16, 2012
10
0
0
CA
I want the datum elements (isolated elements) to appear in a different color than the elements with history, but I want this to be configured, not a properties change inside each part.
Is there a way to configure this?
Thank you
Hi, once i tried to control color with rules, and i did it. LIke you have parameter with colors and you can change it, it was controled with a rule.
Or you can go with a macro, you have that option too.
like to make some palete, and to have multiple selection, then check for parent if there not, change color, or smthg like that.
I hope i helped
