An advice from a newbie to a newbie (If i'm wrong i count on the non-newbies to correct me) imagine the mating part of the part you're dimensioning as the inspection fixture. The datums tell you information about the features of the mating part. Concluding from the way it was toleranced, that sleeve in your drawing sits on a shaft (datum A) with a certain radial clearance to it's internal dia. The sleeve is supported on it's end face (and thus oriented in space) by datum B. A tab (datum C) protruding from the shaft enters the slot, also with some clearance, and limits the rotation around the axis to some level. Now let's say a screw should enter through the hole you toleranced to the 3 datums into a threaded hole in the shaft, and a larger tab should enter through the larger slot into a pocket in the shaft. When assembling, you can take advatage of the clearances i was talking about to move the sleeve back and forth a little bit and spin it a little bit until everything fits. If all parts fit - the part passes the dimensional inspection ☺ This is what the modifiers on the referenced datums (mmb per asme y14.5 09') are saying, usually the maximum material boundary on those datums means that the shaft and the datum C tab on the mating part that serves as your inpection fixture should be produced in their largest allowable size (which are related to the smallest sizes of inner dia. And slot width on your part, respectively). Does this mean that you get a larger toletance zone in production for the controlled features? I think not. It's hard for me to analyze it in this case, but i know that in some cases it may lead to a tolerance stack up that will make assembly impossible. In any way, the mmb doesn't make the tolerance zone larger, but it tells that there is some space for "play" in assembly - it simulates functional assembly in the dimentional inspection.
