Datum planes
loka23
Aerospace
Sep 10, 2010
45
How to reposition the datum plane relative to sketch?
Becasue sketch is revolved to another position but the datum plane in previous position? One command is 'Resize' and Any option is there? Please attached jpg file.......
Since a Datum Plane is technically 'infinite' the idea of moving it WITHIN that 'infinite' space has never really been a high priority. As you have already discovered, the 'Resize' procedure is about the only scheme that we have which will give you at least something close to 'Move Datum Plane' function.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Are you sure this is a sketch? My guess would be that you have basic curves out in space (non-associative lines, arcs, splines). If this is the case, you can add a new datum plane by picking an arc or (planar) spline, or by picking 2 lines. You can then reorder the datum plane in the feature tree as needed. This process would assume that the rest of the entities are coplanar to what you picked, this may or may not be the case with basic curves. If they are not coplanar, you can project the curves to the new datum plane.
