I have a part that is .036" thick, which essentially looks like a ring with tabs around the circumference of the O.D. (part is about 2.3" diameter on O.D., 1.75" I.D.). The tabs are angled slightly to give a lead-in because the part fits inside a tube with a slight interference. The flat ring sits against the surface of another part inside the tube. There is also a cylindrical part that passes through the I.D. of the ring, that fits inside the tube as well.
For setting up the datum structure, in my mind datum A would be the flat surface of the ring that sits against the other part in the tube. Datum B would be the O.D. of the tabs since they determine where the center of the part is when installed. Then I can establish a positional tolerance for the I.D. relative to these datums to ensure there isn't interference with the cylindrical part that passes thru the center of the ring. The issue I am having is thinking of a way to relate datum B back to A. The only thing that would makes sense is to define an orientation of perpendicularity, however the part has no depth to it so that seems non-sensical to me and would be difficult to even measure.
Another thing I thought about was eliminating calling out the flat surface as datum A, and just using the O.D. of the tabs as the primary datum with no secondary. Does this make sense since the part has no depth to it? Really the concern is establishing a concentric relationship between the O.D. of the tabs and I.D. When the part gets installed in the tube, and mates against the surface of the other part, it will get "flattened" out one way or the other, so perhaps that flat surface of the ring is not critical in terms of being defined as a datum.
