DatumCsys
NirVidP
Industrial
IN
I believe that a DatumCsys 'attached' to a datum feature (eg DatumPlane).
So, is it possible to find the DatumPlane to which the DatumCsys is attached? Or in a reverse way, is it possible to get the DatumCsys from the DatumPlane object. I have searched the web and help files, but no clue.
Can the DatumCsys(visisble?) be seen on the screen?
I am asking this because I recorded a journal and it identifies a DatumCsys by JournalIdentifier which I want to replace by generalized code.
I am new to NX, so I would take me a little more time to get accustomed to concepts in and vocabulary of NX. Till such time, I may need help on such possibly simple issues.
I luckily got the answer in the GTAC sample code - 'Create sketch on first dplane of selected datum csys'.
The DatumCSys is the feature and DatumPlane is its 'component'.
The relevant portion of the code:
theUFSession.Modl.AskDatumCsysComponents(DatumCSysTag, CSysTag, OriginTag, DAxisTags, DPlaneTags)
This was a small part of the problem of my other post 'Circle On The DatumPlane'. I am hopeful that this will enable me to solve that issue also.
In addition to the .AskDatumCsysComponents function, you can use a datum csys builder to get the individual components (datum planes, datum axes, csys, and point).
thread561-363348
www.nxjournaling.com
Thank you cowski for your response.
I am trying out an alternative method where DatumCsys is not needed. This issue is related to 'Selection Stickiness'.
