RPMG
- Nov 7, 2014
- 333
OSHA states, "Stability factor means the ratio of the stabilizing moment to the overturning moment." and "1910.66(f)(3)(iii)(A)
Every davit installation, fixed or transportable, rotatable or non-rotatable shall be designed and installed to insure that it has a stability factor against overturning of not less than four." For the pipe base per the vendor, [Ma = 8] <= [Mn/F = 24 k-ft], where Mn = 40 k-ft. Is the stability factor for this 3.0 or 5.0?
I am designing the steel support, not the adequacy of the pipe base, but I was trying to figure out if the stability factor is a load factor or the factor of safety.
