PaulKraemer
- Jan 13, 2012
- 150
I am trying to troubleshoot a DC Motor and Drive Control System on a Printing Press. This is a 10 HP DC Motor with a field winding. It is controlled by a Cleveland MachineControls (CMC) PM3 drive. The speed reference to the drive comes from a digital potentiometer. Control is open-loop (no feedback from a speed sensor). Throughout my troubleshooting session today, I observed that the speed reference from the digital potentiometer is rock solid at 4.18 VDC.
This Printing Press can handle multiple webs that get laminated together in our process. Operators have brought it to my attention that this motor has been “surging” at times during production at our normal operating speed. In a test trial, I found the motor ran smoothly when we were only pulling a single web at a low speed. A clip-on ammeter indicated at this time the motor was drawing 6 amps. After this, we introduced two additional webs. This increased the motor current to 9 amps, but the motor still ran smoothly. After this, we increased to our normal (higher) operating speed, and the motor started surging. This forced us to stop quickly to avoid making a mess and wasting material.
We had changed the brushes in this motor about a year ago. We checked them again and they appeared to be in good condition. When we opened the motor to look at the brushes, we found that there was an oily substance inside the motor body. Investigation led us to the conclusion that this is coming from a glue melter positioned near the press. Every time the lid of the melter is opened, fumes escape into the area of the motor. These fumes get pulled in by the motor fan and pass through / around the motor windings before settling / condensing in the chamber where the brushes are accessible. We are going to take measures to reposition the melter to mitigate this issue.
I am not sure whether to suspect the motor, the drive, or something that might be making the load "irregular".
I am curious if anyone here has experience with a motor being subjected to a foreign substance like this, and whether it might lead to surging at higher loads / faster speeds as opposed to lighter loads / slower speeds.
Any suggestions or advice will be greatly appreciated.
Thanks in advance,
Paul
Thanks in advance,
Paul
