I'm working on selecting a BLDC motor for a robotics application where I require mean torques of about 3 Nm and peak torques of 4 Nm at an average rate of 2.5 rad/s (24 RPM) continuous.
This is a high torque, low RPM operation.
I have shortlisted a generic large air-gap BLDC motor with a 90KV rating (Motor Link (Aliexpress)). This is a popular motor among roboticists but doesn't have a lot of data.
I intend to use the ODrive S1 BLDC driver in torque control mode.
My questions are:
Thanks!
My questions are:
- This is rated as a motor requiring a "12S" battery. Can I run the motor/driver with a "6S" battery knowing that the driver can function on that voltage? Will it affect the motor performance?
- Can I run the motor at my desired torque and speed? I understand brushed DC motor curves enough to do the motor sizing, but selecting a BLDC motor is confusing.
- Will there be a lot of power loss running this motor at my desired torque given that the winding resistance of the motor is high?
Thanks!
