DC output vs AC input in rectifier
ravindranathan
IN
How is DC output voltage of a full wave rectifier higher that AC input voltage?
Peak vs RMS voltage. It's not always more. A single phase rectifier feeding a resistive or inductive load it is less.
What we call AC voltage level is actually the RMS voltage, meaning Root, Mean, Squared, a complex form of averaging across a time period. The peak of that RMS voltage is higher than the RMS, by a factor of 1.41:1, but across time it appears lower in terms of what AC devices actually use/respond to.
But when you run the AC through a bridge rectifier, the diodes only conduct when the AC sine waves approach the actual peaks, so the net voltage created is a rippled DC level and if you smooth out the ripple with capacitors and/or inductors you end up at that 1.41 x ACRMS value for the DC.
That is for an unloaded circuit.
When the circuit is loaded the voltage will drop.
How much the voltage drops depends on the filtering and the amount of loading.
Bill
"Why not the best?"
Jimmy Carter
jraef - smoothing with an inductor produces a DC voltage that is about 0.89Vrms.
