I hope somebody can help.
I have a 240 V 3 phase motor which turns a DC gen and would like to control the start/stop of the moter when I touch the welding rod to the metal to be welded. The problem I am faced with is that I need to test for continuity but to do so would require equipment that can handle 230 amp max.
If anyone has any circuit sugestions to control the motor thus the dc gen and finally the welder output power I would greatly appreciate it.
Thank you
Thank you
