Hi:
I am upgrading a system wherein the client wants to install a deaerator in the existing system. The present system has a consensate return tank, with LP steam supply to it and the feed water is pumped to the boiler. The deaerator is to be installed about 80' away from the condensate tanks. The new system will be as follows:
Condensate returns to the existing tank. It will be pumped to the deaerator and then from deaerator to the boiler.
Any suggestions or tips for designing the system?
