Deafting text multiple lines - change font size only for one line 1
iscariot
DE
Is it possible with automation to change the font size only for one line of text?
you can use the Get/SetParameterOnSubString to modify only on line of the text.
Code:
Dim oSht As DrawingSheet
Set oSht = CATIA.ActiveEditor.ActiveObject.ActiveSheet
Dim drawingViews1 As DrawingViews
Set drawingViews1 = oSht.Views
Dim drawingView1 As DrawingView
Set drawingView1 = drawingViews1.Item("View.1")
Dim drawingTexts1 As DrawingTexts
Set drawingTexts1 = drawingView1.Texts
Dim drawingText1 As DrawingText
Set drawingText1 = drawingTexts1.Item("Text.1")
Dim subLines As Variant
subLines = Split(drawingText1.Text, vbLf)
linetochange = 2
linePosition = 0
For u = 1 To linetochange - 1
    linePosition = 1 + linePosition + Len(subLines(u - 1))
Next
lineLength = Len(subLines(linetochange - 1)) + 1
drawingText1.SetParameterOnSubString catBold, linePosition, lineLength, 1
Eric N.
Thank you, it works with the mention that Font Size must be multiplied with 1000. I'm not sure why.
