bootlegend
- Mar 1, 2005
- 289
I'm curious how everyone handles designing structures around vibrating machinery. For example, in the situation shown in the attached sketch. I have a small structure supported on a larger structure that also supports a large vibrating screen. The screen weighs about 93,000 lbs and operates at 800 rpm. Currently I'm interested in how you would approach the design of the small structure to avoid vibration issues due to the screen. My approach has been to model the structure and check for natural frequencies that fall within plus or minus 30% of the operating frequency. I then modify design if necessary to change the natural frequency. Additionally, I usually use vibration damping pads and bushings beneath the baseplates.
For those of you with access to RISA, you can see in the attached file that this particular structure has a couple natural frequencies that are close to the operating frequency. I'm limited on support schemes and bracing schemes so I'm having no luck with that approach.
Is it possible to determine whether the damping pads will prevent the vibrations in the structure? I've talked to two suppliers in the past who claim a really high percentage of isolation, but I've never had to use the pads on a structure that shows a natural frequency really close to an operating frequency.
What would be your approach to avoiding vibrations in a structure like this?
