Tomy-Met
Materials
- Mar 27, 2019
- 15
Dear Experts, I need your help and i am thankful in advance to everyone especially Sir Metengr.
In our boiler steam drum we found some cracks in fillet welds (propagating from HAZ to Base metal) of feed water inlet nozzles.
Drum material= WB 36
Shell thickness= 65mm
Penetrating nozzle thickness= 18mm
Crack excavation depth= Full fillet weld and 25mm in base metal
We excavated those cracks and welded with qualified WPS, We maintained Prehaet of 100C during welding, after welding hydrogen bake out was continued for 3hrs at 300C.
After hydrogen bake out visual inspection, DPT and PAUT conducted and found acceptable.
AREA OF CONCERN:
We decided to carry out localized PWHT on all 11 nozzles at once, heating band on shell horizontal direction, installing heating pads inside and outside around nozzles.
Contractor has now raised the concern that localized PWHT in this way will cause more stress around nozzles (penetration) and it can cause more cracks or deformation.
Contractor is justifying pwht waiver by saying, hardness values are under limits so no need PWHT.
And i am sure they have not applied temper bead welding as recommended by NBIC and API 510.
Hardness values in base meta 250 and at HAZ 310 maximum.
My concerns are as follows:
- Can we waive the PWHT? aligned to international industrial best practice international codes and standards where applicable, for in-service repairs of high integrity pressure equipment
- What will be the effect if we conduct PWHT and if we eliminate PWHT?
- How can we justify the tempering of the beads by any examination or testing?
- Can we measure the residual stresses or residual stresses are directly related to hardness?
I have suggested them to carry out PWHT for individual nozzle but the concern will be number heating cycles.
I have attached Nozzles and drum photo.
Please let me know if some more detail required.
Please suggests us best solution. Shall be thankful on immediate reply by seniors
AREA OF CONCERN:
