I am doing the schematic design of 36 meter long steel and RCC composite footbridge with a central pier and end supports. The region is seismically active (PGA 0.4g) and maximum temperature change is about 36 deg C. I need advice on how to decide whether any type of bearings are required to be put between the deck and the pier / end supports. Is there any "deciding criteria" given in the European codes for this?
