Decimal places ???
Alan Lowbands
Aerospace
May 17, 2017
274
GB
Can anyone help please.
I'm running a macro that extracts the sizes of a part from the properties boxes to paist on a drawing.
Length width and height.
I can get them with no problem but its returning the sizes to around 7 or 8 decimal places.
Is there an easy way to set then to 3 ?
I'm a bit desperate :(
Fankenstien code below (please don't laugh to hard)
Sub CATMain()
'-----------------Select body
Dim partDocument1 'As Document
Set partDocument1 = CATIA.ActiveDocument
Dim part1 'As Part
Set part1 = partDocument1.Part
Dim oSel 'as Selection
Set oSel = partDocument1.selection
Dim Filter(0)
Filter(0)="Body"
Dim F_Body 'as object
F_Body=oSel.selectelement2(Filter, " Select Body in which you want to add", False)
Dim bodies1 'As Bodies
Set bodies1 = part1.Bodies
Dim body1 'As Body
Set body1 = bodies1.Item(oSel.item(1).value.name)
'--------------Short Name
Set product1 = partDocument1.GetItem("1")
oShortName = Split(CATIA.ActiveDocument.Name,".")(0)
sShortString = oShortName
'------------------------------Material from model
Dim productDocument1 'As Document
Set productDocument1 = CATIA.ActiveDocument
Dim product1
Set product1 = productDocument1.Product
Dim parameters1
Set parameters1 = product1.Parameters
Set product1 = product1.ReferenceProduct
Dim oMat
oMat = parameters1.Item("MATERIAL").Value
'MsgBox oMat
oStock = parameters1.Item("Definition").Value
'MsgBox oStock
'------------------------------Length from model
'Dim productDocument1 'As Document
'Set productDocument1 = CATIA.ActiveDocument
'Dim product1
'Set product1 = productDocument1.Product
'Dim parameters1
'Set parameters1 = product1.Parameters
'Set product1 = product1.ReferenceProduct
Dim oLength
oLength = parameters1.Item("Length").Value
'------------------------------WIDTH from model
'Dim product1
'Dim parameters1
Dim oWIDTH
oWIDTH = parameters1.Item("Length").Value
'------------------------------HEIGHT from model
'Dim product1
'Dim parameters1
Dim oHEIGHT
oHEIGHT = parameters1.Item("Length").Value
'------------------------------Stock from model
' Dim product1
'Dim parameters1
' Dim oStock
'oStock = parameters1.Item("Definition").Value
'MsgBox oStock
'------------------------------Drawing sheet
Set documents1 = CATIA.Documents
Set drawingDocument1 = documents1.Add("Drawing")
drawingDocument1.Standard = catISO
Set drawingSheets1 = drawingDocument1.Sheets
Set drawingSheet1 = drawingSheets1.Item("Sheet.1")
'drawingSheet1.PaperSize = catPaperA0
drawingSheet1.Scale = 1.000000
'drawingSheet1.Orientation = catPaperLandscape
Set drawingViews1 = drawingSheet1.Views
Set drawingView1 = drawingViews1.Add("AutomaticNaming")
Set drawingViewGenerativeLinks1 = drawingView1.GenerativeLinks
Set drawingViewGenerativeBehavior1 = drawingView1.GenerativeBehavior
drawingViewGenerativeLinks1.AddLink body1
drawingViewGenerativeBehavior1.DefineFrontView 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000
drawingView1.x = 594.500000
drawingView1.y = 420.500000
drawingView1.Scale = 1.000000
drawingViewGenerativeBehavior1.Update
drawingView1.Activate
'-------------------Hide axis
Dim selection1 'As Selection
Set selection1 = drawingDocument1.Selection
selection1.Search "Name=*HDirection*,all"
Set visPropertySet1 = selection1.visProperties
VisPropertySet1.SetShow 1
selection1.Clear
selection1.Search "Name=*VDirection*,all"
selection1.Clear
selection1.Search "Name=*Origin*,all"
selection1.Clear
CATIA.StartCommand "Fit All In"
'---------------------Text Box
Dim FullName
Dim DrwNo
FullName = partDocument1.Name
strNewNumber = FullName
sString = strNewNumber
Dim oQty
oQty=InputBox ( "ENTER QTY" )
Dim oDoc
Dim oCurrentView
Dim oTextToEnter
oTextToEnter = sShortString & vbCrLf & "TOLERANCE - " & " SEE TABLE" & vbCrLf & "ROUGH STOCK SIZE - " & oStock & " mm" & vbCrLf & oLength/25.4 & "oWIDTH" & "oHEIGHT" & vbCrLf & "MATERIAL - " & oMat & vbCrLf & "QTY - " & oQTY & "-OFF"
Dim oText1
Set oDoc = CATIA.ActiveDocument
Set oCurrentView = CATIA.ActiveDocument.sheets.ActiveSheet.Views.ActiveView
dim dXY(1)
dim sSelType(0)
set oDoc = CATIA.ActiveDocument
set oSel = oDoc.Selection
oSel.Clear
sSelType(0) = "Point2D"
sSelStatus = oSel.IndicateOrSelectElement2D("Select a point or click", _
sSelType, false, false, false, bObjSelected, dXY)
if sSelStatus = "Normal" then
if bObjSelected then
'An existing point was selected, get its coordinates
set oPoint = oSel.Item(1).Value
oPoint.GetCoordinates dXY
end if
end if
oSel.Clear
Set oText1 = oCurrentView.Texts.Add(oTextToEnter, dXY(0), dXY(1))
'oText1.SetFontName 0, 0, "Arial (TrueType)"
'oText1.SetFontSize 0, 0,5
'-------------------------------UpDate
'--------------copy to clipboard for save-------------------------------------
Dim oNameSave
oNameSave = sShortString & "_" & oItem
Set WshShell = CreateObject("WScript.Shell")
Set oExec = WshShell.Exec("clip")
Set oWrite = oExec.stdIn
oWrite.WriteLine oNameSave
oWrite.Close
End Sub
Sussed that bit but got a weird problem.
The parameters were named "Length" "WIDTH" & "HEIGHT"
When I use the code below it picks up the WIDTH value for both Length and WIDTH ?
Any ideas why ?
Any help would be appreciated thanks
Dim product1
Dim parameters1
Dim oMat
Dim oStock
Dim oLength
Dim oWIDTH
oWIDTH = parameters1.Item("WIDTH").Value
Dim oHEIGHT
oHEIGHT = parameters1.Item("HEIGHT").Value
Dim oLength2
Dim oLength3
oLength2 = oLength'/25.4
oLength3 = round (oLength2 ,3)
Msgbox oLength3
Dim oWIDTH2
Dim oWIDTH3
oWIDTH2 = oWIDTH'/25.4
oWIDTH3 = round (oWIDTH2 ,3)
Msgbox oWIDTH3
Dim oHEIGHT2
Dim oHEIGHT3
oHEIGHT2 = oHEIGHT'/25.4
oHEIGHT3 = round (oHEIGHT2 ,3)
Msgbox oHEIGHT3
