Hi everyone
At first, I've defined a square sheet and then partitioned it to generate a set of 64 element.
I want to make a cohesive interaction between every elements, I mean on the line which they are attached . My question is that, is it possible to do so or I should try something else?
Because it is hard for me define 64 elements and then attach them together.
If anyone helps, I'll appreciate that.
