Hi Structural Engineers
I designed a small RCC building (for a Buddhist temple). A basic RCC frame drawing used for analysis is attached herewith
It having a building footprint of 6.5m x 6.5m ,with Ground+2 floors and with a RCC dual portal framed(different slopes)type roof where the 2 roof frames(4 RCC roof members) connecting at a single apex point.(at the top).Also 4 nos of additional horizontal beams(at the region where the roof slope chnages)also provided for stability of the roof.
The roof to be covered with light weight steel roof claddings and after analysis also found that 225x300mm RCC colums are sufficient for the building structure and roof portal RCC member sizes also to be 225x300mm.Assumed Grade 25 concrete to be used.
I can determine the apex point vertical(downward)deflection by using the same analysis software progarm but I need to know that value is within the acceptable range.
In otherwords I want to know the value of maximum allowable deflection limit for this type of RCC roof frame structure
Dushyantha
Dushyantha
