Totobolz
- Oct 9, 2019
- 7
Good day to all FEA experts.
I am currently working in a Box with a 6 plate-type supports that is bolted on beams.(Attach is the model of the Box).
I am quite confused on assigning the restraint/constraint for the degrees of freedom of the nodes.
I understand that the support will be fixed type since the bolt and nut will restrict the translational movement(Dx, Dy and Dz)
In case the bolt holes in the supports are slotted. What is gonna be the degree of freedom?
Thank you very much in advance for answering my query.
Link
Link
