ARS-Godrej
Aerospace
Hi
I need a dia 80 solid piece of compression molded Carbon phenolic composite
I an Tool I did lay-up of disc shaped pre-preg and put the tool on Ht platen press and cured at 155 degree temperature and cured for 4 hrs.
Post de molding the part splitted in to 2 to 3 pieces. Pl. find image attached
What could be the reason and how to overcome this kindly advice?
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/raw/upload/v1597043536/tips/Image_gggzof.pptx[/url]
