ajay__re
- Feb 6, 2018
- 5
Consider the case of a cantilever frame as seen in the attached picture.
When you consider the roof beam as an individual beam with one end fixed, I consider the vertical deflection limit as span/250.
What would be the vertical deflection limit of the roof beam when the whole frame deflects under wind load? (Say European standards)
Thanks in advance
Thanks in advance
