I am working on a script to automate the clean-up of large STEP imports into NX11. One thing I would like to clean up is a principle axis that is added to every part (not a datum CSYS which I want to keep). I would like to rid my imported model of these. There may be a way to turn it off during the import, but I have so much work into the model at this point, I would rather just script it. As part of the clean up journal I would like to select and delete them in each part/assembly but I can't figure out how to select these in the Journal file because they are not a feature or a body or a datum or anything else I can identify. I was looking for a way to simply dump out everything in the model and see if I can figure out how it is identified, but it doesn't seem to fit into any of the classes I am familiar with. Anyone dealt with selecting these in a journal file? I've attached a small assembly that has a few of them in case you'd like to give it a look.
Thanks in advance,
Drew
Thanks in advance,
Drew
