Demagnetise Al Bronze
123Cat
AU
Its 10 Al 68 Copper and 4% iron
Turned out more Magnetic than 316
So Can it be removed by electric means
I dont want to heat very high as they are longish bars
Thank You
Let me get the grade , that will help
If its not a low perm grade I fear that is the problem , bad matl selection
Anything that can be magnetized can be demagnetized.
Now if it has to be non-magnetic you will need a different alloy.
You can wrap a wire around each bar and run a decaying AC current to demagnetize. It'll require trial & error to determine the correct power settings.
What caused your alloy bear magnetism?
If it is annealed/stablized condition, you are having intrinsic magnetism that cannot be removed permanently even by thermal demag.
if it is cold worked/ quenched etc that caused disorder (strain/segregation/Fe rich cluster), and so magnetism, only thermal anneal can remove it.
Both cases, you can do what Mike recommends to de-mag, but only temporarily. When it exposes to an external magnetic field again, it will re-gain magnetism.
Thnks all
A case of wrong matl selection
My $1 coin exibits no reaction to magnet , does not even move a compass
Mag Mike
Thank you
They have a small part machined , that they could try that on
What is it a heavy copper cable and how much current to start ?
We have a small 60 Watt demagnetiser here I could try that
If you have a small part, you won't need heavy copper cable. Try your small 60 watt demagnetizer first.
If it is a small part your demag unit may work.
But the material is still ferromagnetic, so it will respond to any magnetic field.
In my experience any Cu based alloy with over 2% Fe will be ferromagnetic, below this amount it can be kept in solution.
Thanks Ed Stainless
Clearer picture of whats happening
Wrong matl selection definite
Will try small part just as experiment
