Hey there, In my chloralkali industry a P&F HXchanger (constructed out of Ni) is used to cool 32 w.t% NaOH from 87 to 75 Celsius using Cooling water (CW) available at 32C (in summers)
For previous x2 months the duty of HXchanger duty decreased such that outlet NaOH temperature cannot be decreased below 80C
Flowrates of NaOH, its entering temperature is same (thermocouples & flowmeter). CW flowrate is also same (indicated by pressure gauge at the inlet to HXchanger)
In an attempt to insitu descale HXchanger without disturbing running process I utilized an opening to inject HCl (34 w.t%) at the inlet of CW. Stopped CW flow completely for ~2mins & initiate HCl flow while keeping outlet temperature rise in check! Then again CW flow is resumed & HCl flow stopped after ~15min again the previous ~2min HCl cycle was repeated. In whole of this process outlet point of CW was open to drain (instead of being returned to Cooling Tower)
This HCl flush cycles were done ~6 times after the 4th cycle the outlet pH of HCl stopped increasing indicating no HCl consumption while descaling salt deposits.
The performance of HXchanger (after above activity) slightly increased but to no avail ..it now approached minimum temperature of 79C (a decrement of only 1-1.5C)
Now is there any other activity I should try, anything other than HCl! I believe that our Cooling Tower has deposited silica based impurities & what cleaning agent I should try to remove it.
Regarding Cooling Water specs: 6-6.5 pH; chromate inhibited; 2barg pressure
