Describing Different Types of Structures
MatthewMansfield
47
Hello all
I was wondering if someone help clear up some confusion I have regarding different type of structures.
Below are 4 x diagrams of beams:-
I have seen these types before but what confused me was that when I tried to name these types of beams I got stuck.
I would name these structures as:-
A = Cantilever Beam
B = Propped Cantilever Beam
C = No Idea???
D = Simply Supported.
How would you name these structures?
Also how would you formally define these types of structures?
I have always thought that Diagram C was simply supported????
Can anyone shed any light?
Thank you.
A- Cantilever
B-Propped Cantilever
C-Propped Cantilever
D-Simple support
I agree with the other Ron. Your C option has a pinned support symbol on the left end but your force arrows indicate a fixed end. One needs to change.
I have never seen Option D symbol on the left side before.
A is a cantilever, obviously.
B I would call a fixed-pinned beam. The AISC Steel Manual calls it "Fixed at one end, supported at the other". I guess "propped cantilever" works too.
C is a simply supported beam; the curved arrow can only be meant to indicate rotational restraint of the pinned support. Otherwise, it's no different than B.
D is either unstable (assuming the dot in the middle indicates a pin about which the support can rotate), or a simply supported beam.
D is SS... a pin and a roller.
