I'm working on a concept design where I need some guidance:
I'm designing a rectangular box shape (don't want to call it a pressure vessel yet) which under normal conditions are subject to slight under-pressure: 0,8 - 0,95 bara. This pressure is maintained by a control system.
In case of a process failure (pipe rupture or similar) inside this box, we are also equipping it with a PRV opening before the pressure reaches 1,5 bara, and in addition preventing pressure below 0,7 bara.
As weight is an important factor, we would like to design this "box" with minimum thickness.
The box is normally inerted (Nitrogen) with operating temperature approx. 55-75 °C (storage 0-40°C).
It contains process equipment and is placed onboard a vessel.
Question:
1) Is this "box" considered a pressure vessel based on pressure & temp rating shown above?
2) If yes, which code would you recommend to follow to minimize weight?
I have been looking at EN 13445 Unfired Pressure vessel, which becomes valid if design pressure is above 1,5 bara. But it also says it can be used for pressure below 1,5 bara and for vacuum.
Another important factor for us is to keep the PRV setting as low as possible (somewhere between 0,95 - 1,5 bara).
Your comments on this?
Thanks in advance
Question:
Thanks in advance
