Design for Full Rating condition
Mateus_R
48
Dear All,
Could some one clarify me what the meaning of having a design (Temperature/Pressure) of a valve/pipe according to the full rating condition?
Another point that I saw in one datasheet and is confusing me: For a piping class, the customer inform: Temperature/Pressure Limits: FULL RATING #300 per ASME B16.5... from 0°C to 400°C.
From my understanding, for each value in between 0°C and 400°C I have a different value of pressure according to B16.5, so i'm a little confused about the one I need to use.
Thank you.
Best Regards.
I suspect, and this is also how I define our company pipe specs, is that you have to check that each such condition (0, 50, 100 .... 400 °C), the flange is the limiting factor, i.e. the weakest component. Another way of putting is that you dedign a flange rated pipe spec.
Mateus,
You simply take the pressure rating which is relevant to your design temperature for the particular material as per the charts in B16.5, or am I missing something here?
If your design temperature is between the steps in 16.5, then you are allowed to iterate between the steps in a linear manner.
XL83NL, yes I also have the idea that what the spec. is asking is to confirm that the flange is not the weakest component in the whole range of Temperature.
LittleInch, i just would like to understand how to proceed facing this kind of Temperature/Pressure conditions, since in my opinion from specification this could be ambiguous. I mean, if someone gives you the Design Temperature and Pressure, why they need to specify that you need to design according to full rating condition.
Kind Regards.
If understood correctly, as the piping spec developed with the full P-T rating based on the B16.5, the pipe, fitting, and valve on each piping class can be designed with the same P-T conditions as defined.
For applying to the specific component such as valve or fitting, the process may be presented with P-T valves per Min/Nor/Max conditions. And then, select one piping class which may cover the all the P-T ratings as specified by this process conditions.
