I'm working on a renovation project that has access limitations (aka, up in the mountains, no heavy truck can reach it). I've successfully managed to come up with a design for the roof trusses that allows the 6m (20 feet) span to be covered by two Howe half trusses fixed back to back. All good. Now I'm trying to come up with a solid design for the floor. The span is the same, 6m (20 feet), but this time I can't take advantage of the shape. The material is cold formed steel C100, 1.5mm thick. I would like to know what options would I have to split the distance in two (3m + 3m) while keeping the truss, Howe as well, ~25 cm (~10 inches) high, structurally sound. Also, is there a code limitation on this (in your country)? Am I forced to use one full length profile for the top and bottom chord?
