Dear all,
for acid gas flare systems, do you agree that considering the non-practicality of installing liquid seal vessels for flashback protection from flare tip and a sealing mechanism, the design pressure of the connected vessels including KO drum shall be 7 barg (or 125 Psig as per API 14 J) to accommodate the potential deflagration if it happens?
Or a lower design pressure can be accepted despite the absence of liquid seal mechanism considering the narrow flammability range of the flared acid gases?
Appreciate your views.
