In my opinion, this is the wrong forum to discuss this issue. The "Pipelines, piping and Fluid Mechanics" is more appropriate
First, your use of the term "pipeline" can mean many things to many people.
It is much better to identify the system by code of record and function. You should talk about "ASME B31.1 Steam system" or a "ASME B31.3 Nitric acid piping system"
Once you identify the code for the system, you can discuss maximum pressures.
Second, you must consider both the maximum pressure AND the coincident temperature at the time of the pressure. Piping systems can withstand a higher pressure in the cold condition than when they are hot because metals have a lower allowable stress level at elevated temperature.
Third, you must watch terminology. ASME piping codes use "Maximum Allowable Working Pressure" which is commonly understood to mean the maximum pressure that the system is EVER expected to see ..... PLUS a margin. Margins of 25 to 100 psig are typical .... 'It would be also typical for a process engineer to define a maximum operating pressure based on the dead head of a pump and then have the pressure margin added to determine to the MAWP.... Keep in mind that before a piping wall thickness can be selected, ASME and other codes require a Corrosion Allowance to be considered by the piping Engineer for the specific system Using the above systems as an example, it would be expected that a nitric acid piping system would require a greater wall thickness than a steam system of the same maximum design pressures and temperatures.
The ASME Gods have found it to be to their advantage to use the similar but confusing term MAOP (maximum allowable operating pressure) for Pressure Vessel design. The ASME Pressure Vessel Code, Section VIII as well as many governmental regulations refer to MAOP
There have been many. many discussions on Eng-tips regarding MAOP and MAWP for pressure components
Don't know if this clears things up .... but I gave it a shot !!!
MJCronin
Sr. Process Engineer
