Can anyone tell me a procedure to design an Equal Tee?
The client has been asked us to consider proof test according to MSS-SP75 rely on actual ultimate strength. So i performed an Elastic-Plastic FEA according to ASME viii-2 but the Tee will shakedown because of the high proof test pressure.
Note that design pressure for run pipe is 1400Psi but calculated proof test is 4400Psi.
Thanks in advance for your attention.
