In EN 1993-1-8:2005, section 3.6.1(4), it's stated that "The design shear resistance Fv,Rd given in Table 3.4 should only be used where the bolts are used in holes with nominal clearances not exceeding those for normal holes as specified in 1.2.7 Reference Standards: Group 7."
I can't find clauses about the design shear resistance for bolts in slotted holes for bearing type bolted connection. Are slotted holes allowed to be used for bearing type bolted connection according to EN 1993-1-8? In ANSI/AISC 360-16, it's allowed as long as the slotted holes are normal to the direction of loadings.
