Design Temperature when Full Vacuum Conditions? 1
erkuts
Petroleum
Dec 8, 2016
21
I would like to ask a question. When i looking design values of our pressure vessel, design pressure 27,07/F.V and design temperature 860/121 Celcius.
What dooes 121 Celcius or 250F value mean? Is it permissible outside temperature or another issue ?
I would normally interpret that the 121 C is associated with the FV condition. You should confirm this is true.
Mike
I would take that to mean that the vessel was good for any pressure between 27.07 & full vacuum, and for any temperature between 860 and 121.
I would assume the temperatures are the vessel metal temperatures, not the outside temperatures. Although it would be odd for the lower temperature to be above ambient.
The coincident pressures/temperatures are: 27 (whatever unit) and 860 (whatever unit) and full vacuum and 121°C. You need to design for both conditions.
Just want to clarify: FV at 121 C and at 860 C are very different conditions.
Mike
Design values as below.
What can i say about this pressure vessel ? is 121 C a limit?
121C is coincident with the full vacuum condition. That is consistent with a steam out case. Normally the outlet to this furnace (hence the term pigtails) is 860C coincident with 27.07 kg/cm^2 internal pressure.
Pressure vessels and piping are both designed for coincident conditions of temperature and pressure. Your high temperature will not occur during vacuum.
can we say that steam out should be maximum steam temperature 121 C or after steam out 121 C should not be exceeded?
In which step 121 C is a limit ?
Steam out is what's going to cause the vacuum - after the steam condenses (and if you haven't prevented it by leaving one end open), it will draw a vacuum.
For the purposes of the design, you need a coincident temperature for the vacuum condition. 121°C is a good number for that.
I'm not certain what you mean by "step"?
I mean when internal pressure 27 kg/cm2 and max temp 860 C. No problem.
But when full vacuum condition occurs, we should not exceed 121 C.
i understand full vacuum condition definition as if steam condensates internal pressure will be 0 and we have existing external pressure 15 psi.
