Figure 27.3-8 of ASCE SEI 7-16 (p. 283) shows design wind load cases for Main Wind Force Resisting System of a building for all heights.
I was wondering if this load case is also applicable in designing components and cladding?
I am having a hard time figuring out the load cases I needed to consider for the aluminum corner mullion.
At the moment, I am considering a load case wherein one side is experiencing full positive design wind pressure
and a concurrent full negative design wind pressure on the other side.
Case 3 of Figure 27.3-8, however, shows that 75% of the load should only be considered when loads are acting simultaneously.
