Hello all,
Any insight and advice is most appreciated. I've been charged with designing a sunroom that will be attached to a 1900's unreinforced masonry wall residence on two sides. The short side is 18' and the long side is 36'. The long side is essentially 3 12 ft windows with 6" jambs.
The short side has a centered brick chimney.
The existing structure can't take any lateral connections.
Am I relegated to steel posts in the jambs connected to LVL's to develop lateral stability?
Column to beam moment connections?
Thanks in advance
Thanks in advance
